bob atherton
Just ordered 13m of the 4mm so I will be out of any group buy.
Will let you know how it compared to the NACA5
So, how did it compare?
I'm getting 4mm but it's just 1,5m each side so probably too thick. Not sure if it'll be too much or if smaller is better but the diference in price is not much... Also, I won't be using any terminations, at least not yet.
I'm looking for some speaker cable to go betwen my Exposure xxv and Kans. Struggling to find the usual recommendations and came across this-
http://www.clearly-av.co.uk/v506000.html
Does anyone use or used this? Would be interested in any feedback.
Tony, would you consider Naim as fancy 'voiced' audiophile cable? I'm not one to thow money about for no good reason but I'm still wondering if my 20 year old NACA5 is a good idea in a non Naim system?
Bob when i sold all my naim kit i kept the naca5 as it was in place and easy just to plug it in to any set of speakers. Big mistake but i also have to emphasise in my own environment. I bought and tried several classic speakers and could not find a good place in my room to hear them without too much bass Thinking it was the speakers at fault i sold them. I then changed the speaker cable for some of the old style rega braided cable and my god what a difference in bass control, detail, musicality etc. I never re-tried some of the speakers i had, but i have epos 14's 6 inches from the wall no bungs and no bloated bass.
I've used Naim cable for 25 years. just put VD Tour grade black in, I can honestly say I didn't notice a difference other than it doesn't look so terrible. (I use Naim amps)
