Van Damme speaker cable
Discussion in 'audio' started by Bourneendboy, Aug 25, 2011.
  1. Bourneendboy
    Bourneendboy pfm Member
    I'm looking for some speaker cable to go betwen my Exposure xxv and Kans. Struggling to find the usual recommendations and came across this-
    http://www.clearly-av.co.uk/v506000.html
    Does anyone use or used this? Would be interested in any feedback.
  2. Tony L
    Tony L Administrator
    Not seen that one, but I'm using some of their 'Blue' studio speaker cable in my second system. It seems fine, but I've not compared it to anything. It comes in different thicknesses, up to 6mm IIRC. Mine is the 1.5mm - I just wanted something cheap and easy to route as it's just the TV / office system.
  3. kristoffer
    kristoffer Danish Hi Fi NERD
    Seriously that's what they are called? Does Van Damme use them in his system?! Then they must be kick ass!
  4. martin clark
    martin clark pinko bodger
    Van Damme speaker cables offer lots of copper, and flexibility, at a low price. It's good stuff.
  5. Cereal Killer
    Cereal Killer 432 Point5
  6. Ian Sampson
    Ian Sampson pfm Member
    That's the cable I had my speakers rewired with, as single runs from each drive unit to banana plugs at the other end.
    Very good cable for an excellent price.
  7. Cereal Killer
    Which one Ian, the Sommer Cable or the VanDamme?
    PS, no X-overs then??
  8. martin clark
    Sommer - also has enough copper. Seriously, there's nothing between them.
  9. Cereal Killer
    I agree Martin :) I used it because it's whats inside also.
  10. Interzone
    Interzone pfm Member
  11. Cereal Killer
    Detail is my life.
  12. Bourneendboy
  13. Cereal Killer
  14. Peter Stockwell
    Peter Stockwell deep fried and gone
    Another Sommercable user here
  15. Bourneendboy
    Which Sommer cable are you using chaps, Eclipse or Orbit?
    The Orbit has a very low capacitance.
  16. paskinn
    paskinn pfm Member
    Don't rule out Supra, slightly more costly but still a proper 'value' cable made by the Supra factory (Van Dam et al are probably bought-in things. ) Sadly, if you believe cables make a different then simply refering to the amount of copper etc is not going to get you too far.If you think they all sound the same, buy the cheapest! Me, I use a fairly thick Supra and don't worry.
  17. Cereal Killer
    I've made up a 6m pair with SC-ECLIPSE SPQ-240MKII with Goldplated 4mm solder bucket Deltrons which were £18 from eBay. All in all these cost me £60 to build. I've also put 50mm of heat shrink on the ends of the outer sheath for that pro build look :) left 100mm of the two red and Blue cores exposed.
    The SC-ORBIT-240MKII is used inside my amp. I found this out from this picture and is why i bought the cable, maybe a bit OCD'ish but hey, it feels right :) :
    http://www.perreaux.com/assets/gallery/eloquence/150i/source/150i-Top-Lid-Off.jpg
  18. panda
    panda pfm Member
    anybody try the van damme black series? it has lower capacitance than the blue.
  19. Peter Stockwell
    Elephant 425 in biwire
  20. Cereal Killer
