kjb
Proof reading not always a strength
I'm currently using a Dynavector P75 Mk3 phono stage between my Gyro with DV20x2(low) cart and my Leben amp. The phono stage is now the only solid state part of the path.
I'm interested in trying a valve based phono stage but don't want ( i.e. cant afford) to have to get either a SUT or change the cart to MM - at least not at this stage.
1) Are there any recommended valve based phono stages that can support both MM and MC under £1000?
2) Would it be worthwhile change? I moved from solid state amps to valves and wont be going back, much preferring the presentation of the valve system.
