Afternoon all, as a valve newbie, l have the chance to procure some ( " have not been used for a while" Edicron ECC83 printed on them is 'HOJGO', could l use them as a phase splitter in my hybrid amp or should l snog/marry/avoid?
Thanks.
I had some Edicron ECC83’s that came with my Croft Micro 25, they were rebadged JJ’s. Sounded just fine and still going after two years or so.
A lot will depend on what date any of the badged valves were made.
Edicron have been going a long while, although I am unsure exactly how long - no doubt Google will tell you. If they have badged valves in the last 40 years, the great bulk are likely to have been from the small number of factories still in operation and as valves become more recent, the number of potential manufacturers has dwindled (to 5? 6? or so at the moment, but with new supposedly to open). Windfall finds of sufficient numbers of old, old stock apart.
As for JJs - I have some, but with the power amp dead at the moment, I can't compare them to anything.....maybe this weekend???? I'll update my thread about ECC83s when I do get round to comparing more manufacturers' valves.
Is the ECC83 reckoned to be the one to change in a Vincent to tweak sound?
Did you have anything to compare them with?
What do you mean by an uplift?
There are STACKS of NOS and/or tested ECC83s at under £15 per, even more so as singles, just not Mullard (that is basically anything with the Mullard badge, irrespective of age and manufacturing source, apart from used and low gain, and brand new). Be careful about what you are really buying though in terms of brand/manufacturer.
FWIW, Mullard ECC83s (based entirely on as many as 4 from the early 1960's!!), are not really to my taste - too casual in presentation - great for rocking me to sleep but not for making me rock - at some level, somehow I want to be grabbed by what is playing.
