david ellwood
Kirabosi Kognoscente
A friend had a fault with his Linn Kairn which was fitted with a Brilliant PSU.
The problem was that it worked fine for about an hour before giving up the ghost.
Having replaced all the usual suspects of electrolytic capacitors I decided it was likely
an overheating issue and so tried looking at the board with an infra red camera.
Interestingly this clearly identified one of the MosFets as 25°c hotter than its twin.
Having replaced this component the PSU is now working fine.
