I bought about 60 of these for all the ppl I my dept for LD1, no complaints so far.
https://www.amazon.co.uk/dp/B000UXZQ42/?tag=pinkfishmedia-21
Personally I hate headsets.
So unless you really need one for privacy reasons then I would buy one of these
https://www.amazon.co.uk/dp/B00ANI7HI2/?tag=pinkfishmedia-21
brilliant, I wouldn't be without mine
For long term use wireless is much better to work with
We use these Jabras also, not cheap but excellent quality. It’s also great for placing in the middle of long tables, the software sort of amplifies the sound of those seated further away.if you have privacy and can get away with it, no headset is best. Speakerphone
Should do everything you need, buy from Amazon easy to return. If you don’t need wireless the 410 would do, few quid cheaper.Ok, Jabra was an unknown brand to me so I'll sort something from them.
With the Jabra 510, can that also be used as a Bluetooth speaker - I often listen to Podcasts and an uplift in voice quality over stock laptop speakers would be handy. I used to play them through Sonos Play 1 (not Bluetooth one) but just can't be arsed sodding around with it at times
It can, and has great PRaT, as it is made for speech frequencies. As a result, the bass response is not that of a Klipschhorn.With the Jabra 510, can that also be used as a Bluetooth speaker
