Jack Barriere
Me, you and them
A bit disappointed. I would go mad. Once you get it going a cooking combo.
Very unlikely. Firstly they are very durable. Secondly it would be extremely unlikely for both signal connections to go bad simultaneously, and third if the common ground was out (the most likely explanation for both signals being disrupted in parallel) you'd not get the power either....My conclusion (so far=) is that either my 4-pin din-din between 112x and 150x is faulty with regard to the audio signal (highly unlikely though?)
Or the CD is not outputting an audio signal. Do you have another source you can try?..or there is some obscure fault with the 112 that cannot be detected by someone like me (must have occurred since yesterday at the sellers house...)
Maybe the seller would agree to let me test it at his place.
On thing about the hiss though, it is constant and does not, as far as I can notice, increase by turning the volume up. Does this tell anyone anything?
This means your amp is not at fault. Very GOOD. This means your pre is not sending any signal to the amp.
