Good afternoon I have an ultrasonic cleaner that I want to use for various dirty, greasy, oily car and bike parts. Can anyone please recommend a good cleaning solution - preferably DIY?
IME oil / dirt / grease is best removed with petrol but I wouldn't want to do this in an ultrasonic cleaner 'just in case' because obviously it is quite flammable. Might be OK if you have a lid to put on it. Normally I find two rinses through minimum is good enough, one to release most of the crud and at least one as a clean rinse. It can also help to filter the petrol for the final rinse, kitchen towel works well for this in a funnel.
AP
Stevec67,
Yes, agreed. The only reason I use this is because I generally use very small quantities for small items and as I use a petrol mower, usually have a quantity easily available. Just don't smoke whilst doing it. As you say, diesel would be a good alternative.
AP
Diesel also stinks, it's horrible stuff to use. However it is a mechanics' friend. Take your nasty black item that's gummed upsolid and impossible to dismantle, chuck it in a bucket of diesel, walk away for a few days. Great for things like 2 stroke carbs full of dried up 2T oil.
As a bike commuter I am constantly servicing my bike and I find white spirit good in terms of smell and flammability given how good it is at cleaning bike chains and derailleurs.
Cheers
Ian
