I'd like to use the TV aerial wall connector in my living room for my tuner and fit a FM aerial in my loft. I don't need a TV aerial in this room so can disconnect the TV aerial in the loft and would like to connect up an FM aerial in it's place. Could this work? Would the existing wiring from the loft into the walls be useable or a problem?
The connector in my wall is I think routed to the end of this cable:
Can anyone identify this connector? If I can find a female version I'm hoping I could just plug an FM aerial to it and then get an FM signal at the wall.
Finally I also need to be sure I am disconnecting the correct wire and as I have no TV I cannot really test this. Can I do so using a multimeter?
