sq225917
Bit of this, bit of that
Phi , logic always applies. As much as one may wish to disregard physics in Favour of audio magic and wishful thinking it will unfortunately never take you anywhere but up blind alleys.
If an idler wheel softened up enough at 78 to remove irregularities then it must by default be too soft to hold its own shape and would then be subject to the same degradation as all other rotating rubber wheels that had reach a level of plastic flow. If you don't understand the materials science that's fair enough, but when the data and the experience pool tells you that you supposition may be incorrect- guess what?
