The Linn motor obviously does perform worse under light load, hence the bearing mod making the difference to smoothness. You can feel this by holding the motor with standard vs modded bearing.
I have also been experimenting with gnu plot.
It seems to me that the problem with an eddy current brake is that the resistive load is itself governed by the velocity of the platter and is therfore prone to being modulated by the very thing it is supposed to be governing.
Those are just the harmonics of the tone. Cartridge, tracking, the orginal tone all conrtibute to those. I cant imagine how speed variance would alter the harmonic distortion.
What we are doing is FM demodulating the signal, using the 3150hz as a carrier. This give a waveform of the speed variance, which can than be looked as a spectrum to locate the peaks of modulation.
Welcome to the reality of analogue replay.I was surprised at the strength of the harmonics, I was expecting a purer 3150hz sine wave.
More load means more torque is required to achieve steady state which means a bigger magnetic field which means more current is needed from the power supply. I can't think of a reason why the motor would function better under those circumstances, so maybe it is the power supply that is able to function more precisely?
It turns out that FM demodulation doesn't care what the carrier frequency is. But I cannot remember if I had to pay attention to it to do the Hilbert Transform. Things seem to work fine regardless of the sampling frequency (if you didn't know then a 48k sample of 3150Hz is indistinguishable from 96k of 6300Hz.)Your carrier tone though is not precisely 3150hz, do you account for that?
Empirically sensible results come out regardless, but I usually narrow band filter the signal before demodulation to remove noise and put the various sources on a level playing field.What affect do the higher order harmonics have on demodulation?
"as the load on the synchronous motor increases, there is no change in its speed. But what gets affected is the load angle 'δ' i.e. the angle by which rotor axis retards with respect to stator axis."
This certainly changes the shape of the interacting magnetic fields (between the stator and rotor) and therefore could make rotation smoother.
A friction (viscous fluid) based load will also be velocity dependent
