Which one is outputing 230V/50Hz , seems they sell few different options ?How about a Hercules from Stamford Audio
All of them I believe, well actually they output two 110v phases, most 230v turntables use a 110v motor with a selection of capacitors and resistors to drop the voltage and provide phase shift, you bypass this circuitry with a PSU like the Hercules.Which one is outputing 230V/50Hz , seems they sell few different options ?
There is Wave Mechanic 230V/50Hz version sold under AnalogueWorks brand for whooping £795 .
I can't see the motor as it is in a housing under the platter but the TT just plugs directly into the mains without any controller. To change speed I have to remove the platter and alter the belt on the pulley so I guess it is a 240vac synchronous motor, I did find this in a review:Ego, what motor does the wb use?
I also asked Heed and Isokinetik regarding my WBCircle and didn't get a response either...DIY route might be the way to follow, thanks for the link "daytona600"
I've been in touch with Heed , they say Orbit2 won't work with CA tables but they're not sure what motor it uses , after sending all details no reply , Isokinetik no reply neither .
I was just thinking of suggesting Rega’s 24v motor and the Neo PSU, they do a sterling job on my P5... you’d have to find a way of housing the anti vibration/input board for the motor but it would be fairly easy to do. What is Meldano’s controller? it not something I’ve heard of.Honestly, rega 24v motor and Meldano's controllet, nowt to touch it under a grand
