I am trying to find the values of some coils that the labels have fallen off for. When I test two known pieces (one is a .28mH, the other 3.5mH) the results are consistent each time but the first is about 12% low/off and the second maybe 16% low/off.
I've tried with 2 different meters. They are both cheap devices one is a dedicated LCR and the other has transistor/diode, ESR features as well. Both report values lower than expected and are within maybe 5% of each-other. Yes I zero the devices. Capacitance measure perfectly.
So is it possible that you don't measure coils just by attaching LCR directly to stripped wire ends?
On same subject... is there a proper way to measure inductance and capacitance of a wire pair? My thought is that for inductance I would connect the meter to wire A on one end and wire B on the other. For capacitance just to A and B on the same end (open on other end.)
Thanks for any help!
