Tidal Masters (MQA) using ChromeCast Audio
Discussion in 'audio' started by radamel, Aug 17, 2018.
  1. radamel
    radamel Music Fiend
    Perhaps this isn't new to you.
    Just found that if you have an MQA enabled DAC the mconnect app allows you to use a Chromecast Audio as Tidal Masters (MQA) streamer:
    http://www.conversdigital.com/eng/product/product04.php
    Well worth paying for this one.
    There is a lite free version that doesn't work as well (e.g. 24/352.8 doesn't run smoothly) but it's good enough for a simple test.
    Sean K and Mark Dirac like this.
  2. radamel
    radamel Music Fiend
    Theoretically it should also work with any DLNA/ UPnP capable streamer.
    So no need to use Tidal's desktop app.
  3. Mark Dirac
    Mark Dirac pfm Member
    Thanks for this. I find it remarkable. Have I understood correctly please?
    • Does one cast from the Tidal phone app, or the Tidal web app, or the Tidal Windows ("desktop") application?
    • What is used for the UI for browsing/transport controls - the Tidal program, or the mconnect app?
    • Can this set-up manage pass-thu MQA, ie, pass the MQA stream to the DAC? Or is something upstream doing the first unfold and then passing the result of that though Chromecast to the DAC?
    Thanks, Mark.
  4. radamel
    radamel Music Fiend
    Hi Marc,
    -One casts from the mconnect app;
    -the UI is the mconnect app's;
    -afaik it only works as MQA pass through so you need an MQA enabled DAC.
    Hope this helps!
    Mark Dirac likes this.
  5. misterdog
    misterdog Not the canine kind
    Wow.
    - Gapless Playback by App and to UPnP renderers.
    So it can play gapless, just like vinyl used to in the old days. It doesnt feel the need to include a random gap at the beginning or end of a track when one doesnt exist.
    There's progress.
    Audio nirvana maybe ?
  6. Tin
    Tin Well-Known Member
    Is it me, or does the above conversation sound a bit like a daytime TV commercial?
    "Hi Mike, look what I got" "Wow, what is it?"
  7. radamel
    radamel Music Fiend
    Gapless playback to UPnP renderers. Unfortunately, gapless does not work with Chromecast Audio.
    I think that misterdog's post was quite ironic.
    And it doesn't even apply to Chromecast Audio rendering...
  8. Tin
    I agree, and I agree with his sentiment too.
    My remark about daytime tv though, was meant for you.
    There are already a few other threads about MQA, so let's not start all that again.
  9. radamel
    radamel Music Fiend
    I wrote my OP in August, before you were a well known member of Pinkfishmedia.
    If you don't like it, report it to the Thought Police.
    Or just bugger off.
    Darren and Mark Dirac like this.
  10. Tin
    And yet more daytime tv. :rolleyes:
    But don't ya worry, I wear a Tin foil hat, so the thought police doesn't have access to my thoughts.
  11. radamel
    radamel Music Fiend
    You didn't get it, did you?
    Can't say that I'm surprised.
  12. Tin
    No, I didn't. Could be worse though; I could be found promoting MQA on the internet.
  13. radamel
    radamel Music Fiend
    You can promote whatever you want...
    You're doing a fine job promoting your ignorance.
    I certainly have no interest in interrupting you.
    Darren, serendipitydawg and suzywong like this.
  14. Sean K
    Sean K pfm Member
