Jimbobbyron
I am trying tidal Hifi at present but I am not sure if i have it set correctly....
My MacBook is connected to the router with Ethernet cable I am using a usb cable to connect the MacBook to my Hegel H360. When using the settings on tidal to output to my Hegel it is not visible and the options show internal speakers or output to speaker. I can listen with the output to speaker option through my Hegel but I don't know if this is the best way of doing so (is it using the Hegels dac or is it the MacBook?)
Any advice would be greatly appreciated.
James
James
