Hound
You seem to be describing (and perhaps prefer and/or are more accoustemed to) the Naim 'sound' with its 'mid-bass hump'?
Andrews
I am sure you will like it, as the xps does have to work hard powering the NDS and adding a second one helps out alot.
I found it ran very hot with just one teddy xps, and was still quite warm even with both, but then socket one does use most off the power rails and socket 2 only 2 power rails i believe.
You can try and if you dont like always return it
Andrews
Think its all been covered over the pages
Thanks for the the updates Dunc, I think I will keep my Xpsdr then, and add the Teddy Xps+ when funds allow it. I want to add a pair of Harbeth 30.1’s before the PS, so it might be later this year.No Quarter
That i dont know as never tried that, or even heard a naim xps dr, but if it was me i would just add the xps + and keep the one i already have.
Well its been a few weeks and in that time i have been using naim 555psdr on socket 1 and teddypardo ps on socket 2 using the standard naim burndy cables and custom cables mains leads, plenty of time to get accustomed to it, especially on my favourite tracks right now.
So with the weather horrible today, i decided to switch back to just the naim ps and play a few tracks to see if i felt something missing, on with Norah Jones first, first off it sounded more closed in, here voice not quite so strong and just slightly lacking, so i swapped it all back while everything was still warm and yes it all opened up once again, was quite taken back as before i had found it much harder to separate them. Maybe the teddy is nicely settled in now or maybe this particular album highlights it more, but rather than keep on swapping them, decided to leave it on both.
So my final conclusion on this is, YES go for it.
Any NDS user's out there with a 555ps and fancy a nice improvement for not that much, especially compared to what a naim 555psdr will cost, order yourself one, give it about 4 to 6 weeks to fully settle in and enjoy.
One other point i must add is that i have also just added a better melco to my system, was using a N100 to play my stored music, but now have a N1ZS/2, now this could be the reason i am hearing a much bigger difference than before, but as i said above the twin set up is staying as it has certainly lifted the NDS to a new level.
That is good news, look forward to your thoughts after you get more hours on it.I have just received m TXPS+ to add to my TXPS / NDS.
Straight out of the box, there is an improvement.
I hope I will not need to wait 4-6 weeks that you mentioned.
My recollection with ther TXPS was that it began to 'Sing' after a week.
My TXPS still fels warm, but the TXPS+ is cool to touch.
Having read this thread I decided to give the TXPS+ a go. I’ve been using a Naim XPSDR to power both the analogue and digital on my NDS so the Teddy Pardo will power the digital side and the XPSDR analogue, with Naim Burndy cables for both power supplies.
The TXPS+ arrived today but unfortunately has been damaged in transit, the plastic front plate is cracked across one side. The package has clearly been opened at the top and resealed with different parcel tape. The inner plastic bag has been torn open so somebody (Customs?) wanted to see what was inside. There is a possibility that some of the internal protection has been removed or redistributed and the package dropped on a corner which caused the damage. Having said that, the box and inner protection material appear to be fairly basic in the first place.
But as far as I can see it is only the front panel that is damaged and I’ve emailed Teddy Pardo to see if he can supply a replacement panel rather than having to return the whole thing
Anyway, I plugged it in and the front light came on so it powers up OK. I’ve had it powered up for about five hours so far and already there is a significant improvement compared with using the Naim XPS alone. Overall the sound is smoother with added depth and clarity, with a tighter bass. So a decent upgrade so far.
Can I ask where you live?, I was just wondering if certain countries have stricter customs searches than others. Regardless, they should replace the packaging properly so the unit is not damaged. I am also thinking about getting an XPS+ to go with my Naim XPSDR, on my NDS. I have the Naim burndies, so is it possible to try switching the Teddy to both sockets? I thought it was recommended to remove the link plug, and use the XPS+ there only. I thought by doing this, the Teddy PS went on the analog side, you mention that it powers the digital side.
