Technics 50th Anni SL-1200 Mk7
Discussion in 'audio' started by Amber Audio, Apr 7, 2022.
  1. Rodrat
    Rodrat pfm Member
    Just rang djkit, I was the 5th to order, three delivered mine should arrive early July.
  2. Whaleblue
    Whaleblue Southbound
    I called Richer earlier in the week as I had half a mind to also get a White one. None available to order in any colour. May come back into stock, but don’t hold your breath I feel.
  3. Pinky
    Pinky In suspense, not compressed
    If I was going for one of these I really wouldn't know which colour to pick..... except that it wouldn't be beige!
  4. farfromthesun
    farfromthesun pfm Member
    Still waiting on a green one from DJKit.
  5. Whaleblue
    That linked one is no longer available. Not sure if that means it actually sold?
  6. John
    John Rack’em Up!
    The green is likely the only one that looks halfway decent with that garish gold colored tonearm.
  7. PerF
    PerF Scandinavian Member
    I wonder if there's any sense in getting a black anniversary, same deck as MK7 (non anniversary) ?
    Paying extra for a product number plate and Gold color tonearm, maybe a few other cosmetics.
    Anyway a cool turntable, I sort of getting used to the different colours.
    A friend just got a Black #03268
    highest number so far in this thread.
  8. Whaleblue
  9. Pinky
    Nice!
    They have two green ones in stock as well it seems.
    chartz and Whaleblue like this.
  10. Tony L
    Tony L Administrator
    The white is really cool. I’m curious as to how well they’ll wear after a bit of use. I suspect the white and yellow in particular could end up looking rather tatty pretty fast as matt finishes tend to buff to a really uneven sheen if you try and clean it. The paint is striking, far more intense and far more matt in real life than pictures capture. It is quite a radical finish, I can’t think of anything like it. I just hope it is hard-wearing.
    Whaleblue likes this.
  11. PerF
    Just found out the arm-rest and arm-lift of mk7 and 1200GR behave similar.
    Arm-rest is set fixed too low(can't be adjusted ?)
    When you lock arm into arm-rest the arm-lift is sort of being pushed down.
    My setup, I need to re-lift arm-lift, otherwise stylus may be too close to record.
    Quite annoying.
    hope this makes sense.?
  12. Tony L
    Surely you only lock the arm into the rest for transit/moving the turntable? In the normal rest position it should be fine. I’ve never clipped/locked an arm into the rest on any turntable I’ve owned unless I was actually moving the turntable or removing the arm. I’ve always figured it places unnecessarily stress on the bearings and can even leave marks on the arm-tube (check pretty much any SME V as an example here!).
  13. Amber Audio
    Amber Audio This is the Day
    Per, I’m not sure what you’re issue is - do you want to lift/lower that arm rest or are you having a problem with the actual arm height? Locking do you mean the flip over clip half way down the arm or the release/lock on the arm base?
    Maybe this?
  14. John
    John Rack’em Up!
    Do you have the tonearm height adjustment set correctly for the given height of your phono cartridge?
  15. Tony L
    One issue with SME headshell fit arms is there is no standard height from the bayonet fit socket and the cartridge mounting surface. As such the position of the cueing platform can vary quite a bit as it isn’t a constant with flat VTA. Hope that makes sense, it is hard to put into words what I mean, but change to a third-party headshell and there is a very good chance the cueing platform will need adjustment.
  16. PerF
    Yep thats what I meant, I sometime secure the arm by the clip but armrest sort of push armlift/arm a bit down.
    Tonearm height and armlift height is otherwise set correct for my needs.
    I have tried various cartridges and always had this issue - need to relift arm, a friend have similar issue with his new MK7L, so we thought others could chime in if this is normal.
  17. Amber Audio
    Can’t you lower the armlift if it is stopping the arm dropping into the bottom of the holder so it clips without downward pressure? If it bothers you use a shim or thicker/doubled up mat and raise the arm itself.
  18. hockman
    hockman pfm Member
    You are supposed to lock the arm only with the arm lift lever in the 'down' position, not up. Does that work?
    John R likes this.
  19. Amber Audio
    You’re not supposed to secure the arm with the arm lift raised. You need to lower the arm lift so the arm drops into the holder and then clip it. Doing it with the arm still raised will put stress on things and likely cause some damage over time or at minimum weaken the arm lift mech. I’ve never seen anyone clip an arm with the armlift still raised.
    Whaleblue and Bob McC like this.
  20. Whaleblue
    I never use the clip unless physically moving the deck (rare, clearly!), and would lower the lift to do that. Surely just moving the arm back against the rest but still raised is the simplest approach? Not judging, just wondering why anyone would do otherwise?
