eddie pugh
I've been trying to get my head around a fairly basic SMPS from a Toshiba DV-R16 DVD/VHS combo recorder player which a friend has asked me to look at and see if its beyond redemption.
Its completely dead so out with the power supply board and the first stage rectification is working. I changed the HOT side reservoir cap which was shorted and now am reading about 330 volts DC on the cap. Next I checked all the caps on the COLD side swapped out a few that were reading a bit low but sadly no joy
I checked the input to the transformer and I was not getting any AC volts so I thought something in the HOT side that was supposed to oscillate and bump the 330v DC up to something really high frequency AC for the transformer to do its stuff was not working. I whipped out Q1001 which is a K3566 Silicon N Channel MOSFET and found it was shorted so I thought worth a try (really great next day service from NIKKO electronics on the bay by the way) More solder fumes but sadly still no cigar.
Now feeling like throwing the whole thing in the trash but can't even go to the tip so its sitting here challenging the old grey cells
I should add I'm not an electronics man but like to dabble and learn and after a bit of research I'm thinking that either the optocoupler IC or one or both of the other transistors on the HOT side must have gone.
I know that SMPS have a high frequency oscillator on the HOT side to function and an optocopler to provide feedback from COLD to the HOT side to regulate the supply.
I thought maybe it was not getting enough load to snap into action but even after connecting it back into the main board and chassis there was no glimmer of response on pressing the on/standby switch
I've added below links to the really poor circuit diag from the Toshiba Service manual and physical board layout and a photo
https://i.imgur.com/KpMfazG.jpg
https://i.imgur.com/5RjTpZz.jpg
https://i.imgur.com/x7YnzeQ.jpg
https://i.imgur.com/1YkaaaC.jpg
Any advice would be really appreciated
eddie
eddie
