Ciunas Audio
Trade: Ciunas Audio
ZK has replied so he will be next to receive the SC PS
koobre, if you are still interested, let me know your address, please.
I enjoyed my time with the 5V SuperCap PSU into my Chord Qutest. The DAC is meant to be immune to power supply changes but I thought the SCPSU gave a very worthwhile all round improvement. In particular it sounded more natural but still with greater separation, detail and dynamics. I'm looking forward to see whether the 12V version does similar thing to my SOTM SMS2 Ultra Neo streamer. If it does I'll be ordering a multi output version.aspro is ready to send out the 5V SC power supply - koobre or ZK PM me your address if you are you ready for it.
none of my devices go 'poof' & I'm trying to make it fool-proof.Re Switchable Bigger vs. Modular: Certainly Modular is far more versatile, especially if there is the possibility of tapping at multiple positions. Just should be fool-proof and not go poof.
Yes, I think you mean a base unit of 12.5V can be added to & built up to 25V, 37.5V, etcAlso, Modular would enable topping up after-firstbuy.
My thinking has changed somewhat since I first posted - I'm trying to rationalise the number of PS units I offer (I don't really want to get into once-off tailor-made designs, particularly when I offer a 30 day return policy).
My thinking now is that I will have a 2X5V PS unit as is currently touring PFM members & a second design which will have a max 12.5V output (obviously in a bigger case). People can order this with multiple outputs in 2.5V jumps - 5V, 7.5V, 10V & 12.5V or any combination of these, would be options .
A second 12.5V unit can be attached to it in series, to provide another 12.5V, i.e a max of 25V & again this will have outputs in 2.5V steps added to the 12.5V of the first case - so 15V, 17.5V, 20V, 22.5V & 25V. A second charging SMPS could also be attached. All outputs are turned on by the on/off switch on the base unit
I'm hoping to tour these versions with all these outputs available but the retail version requires the user to specify which voltage output(s) they require and this will determine the pricing. I'm still working on getting a final price & the pricing logic
I took on board the feedback from earlier about the number of boxes that would be required if it was based on a 5V base unit - building a 25V supply would have required 5 units. With 12.5V units it only requires two units but remains very flexible
Yes! There are many ways to configure outputs & I'm investigating which will provide the maximum flexibility & functionality within the constraints that it is a build I am comfortable with.Can I confirm that the second bigger box unit could provide two 5v outputs as well one 12.5v?
Thanks. The more expensive version sounds interesting but maybe a bit OTT with 6 outputs. For most people I would thought 2 or 3 outputs all variable would be more attractive.Yes! There are many ways to configure outputs & I'm investigating which will provide the maximum flexibility & functionality within the constraints that it is a build I am comfortable with.
For instance, I could allow the user to specify the combination of outputs they want at time of order (double outputs included) - so 2X5V & one 12.5V output would be specified at time of order.
Another (more expensive) alternative would be to provide one of each voltage output - 2.5V, 5V, 7.5V, 10V, 12.5V & another output whose voltage is selected by the user using a 5 position selector switch with a small screen that shows voltage of this output. This gives the user a lot of flexibility with 6 voltage outputs.
The total current being drawn from all these outputs is constrained by the wattage of the SMPS (currently 12V 4A i.e 48W) & the thermal considerations of the case - both of which will be reviewed
Thanks for the feedback but you don't have to use all 6 outputs - the idea being you plug a DC lead into whatever voltage output(s) you want (& this can vary over time as you change to equipment with different voltage input). Variable outputs requires similar wiring & a voltmeter with LED screen which is no cheaper than 5 fixed outputs - I'm also constrained by the dimensions of the back panel. The only advantage I can see with 3 variable outputs is that you could have 3 outputs of the same voltage - not sure how much demand for that?Thanks. The more expensive version sounds interesting but maybe a bit OTT with 6 outputs. For most people I would thought 2 or 3 outputs all variable would be more attractive.
I see. Having 6 outputs would certainly give a lot of flexibility if the cost is not excessive. I know you working on that. Are going to trial that version if you decide that is the way to go or maybe a discounted version for initial buyers?Thanks for the feedback but you don't have to use all 6 outputs - the idea being you plug a DC lead into whatever voltage output(s) you want (& this can vary over time as you change to equipment with different voltage input). Variable outputs requires similar wiring & a voltmeter with LED screen which is no cheaper than 5 fixed outputs - I'm also constrained by the dimensions of the back panel. The only advantage I can see with 3 variable outputs is that you could have 3 outputs of the same voltage - not sure how much demand for that?
Yes, 5 outputs plus one user selectable output could give a lot of flexibility as would two rows of outputs - 5 outputs in each row (2.5, 5, 7.5, 10, 12.5V) - no need for selecting via switch - just plug into the output needed.I see. Having 6 outputs would certainly give a lot of flexibility if the cost is not excessive. I know you working on that. Are going to trial that version if you decide that is the way to go or maybe a discounted version for initial buyers?
