mark.king
I was playing a record and suddenly it sounded really bad and skipped back. I took a look at the stylus and it was gone! Not sure what did it or if it was just age as there was no big crack or pop.
I’ve put in an ATF3 that came with the deck probably 15 years ago when I got it 2nd hand (The blue point was fitted but this was with it also). This is working ok although a lot of gain required which will be due to the low output. To be honest I rarely use vinyl so it will do for now.
So I’m about to put the blue point in the bin as it’s probably not worth sending off anywhere as it’s quite old now and looking at the reviews I’d probably be better getting something else. Especially since I only have a mm phono stage.
So does the bin sound like the right place for it?
