Subwoofer setup
Discussion in 'audio' started by Sam Smith, Mar 21, 2023.
  1. Sam Smith
    Sam Smith pfm Member
    I'm looking for a simpletons guide to integrate to integrate dual subs in a room.
    So far I have Rew and a Umik2. There are so many guides that seem to be specific to home theatre but nine that applicable to a 2.2 setup.
    How do I match the volume of the subs to the speakers would be a start?
    Any pointers would be much appreciated.
  2. Purité Audio
  3. Sam Smith
    Thanks Keith,
    I'm using Proac Tablette 10 Signature and 2 Rel Tzero MK3 in a small room 15x12 feet.
    I'm not using mini DSP so I guess just cherry pick information from the guide?
    In terms of placement I have the speakers about 2 meters apart but the only two placement options for the subs are inside the speakers or one in the corner by one speaker and the other sub diagonally opposite in a corner.
    Seems to be the whole sub thing is a bit of a an art in it's self.
  4. Purité Audio
    Measure with REW left and right and then together use the software to take a photo of the results and post it here.
    It might be best to measure the speakers without subs first, is there anything you can adjust on the sub, phase, gain, filters>
    Keith
  5. Sam Smith
    Thanks,
    On the Sub there is crossover setting, gain and 0 or 180 switch.
    I'm about to get a couple if granite slabs to put under the subs to help with a suspended floor. I'm thinking of placing the subs just inside either speaker.
    Will try and get some measurements(hopefully) and take it from there.
  6. Purité Audio
    I sincerely doubt the granite will make the slightest difference, and there is nothing wrong with a suspended floor just another contributory factor to the whole FR of the room.
    Once you know where the mains roll off you can at least set the frequency/filter for the sub and the FR will give you an idea of the gain required.
    Keith
    jamington2004 likes this.
  7. Sam Smith
    Ok cheers,
    Should I just measure the subs with the crossover set to max and a moderate amount of gain?
    Cheers
  8. Purité Audio
    Sam I am not familiar with that sub, but I imagine when they say ‘crossover’ they mean a low pass filter, so if your main speakers roll off at 80Hz you might set the sub so that it doesn’t output any frequencies above say 70Hz, you don’t really want both speakers and subs overlapping.
    You can probably adjust the gain by ear if too bass heavy relative then turn down the gain.
    Everything will be clearer when you can see what you are hearing.
    From the KEF ‘how to set your sub’ page,
    Keith
  9. Sam Smith
    Thanks very much for the info will get some measurements
  10. Sam Smith
    Here is a link to the measurements (hopefully)
    https://postimg.cc/S2w3VcNL
    https://postimg.cc/XrRsRn03
  11. Purité Audio
    Sam set the vertical range to around 60dB, with the scale you are using everything is tooo smoooth!
    Keith
  12. Sam Smith
    Ok will try. I'm not that clear how but will try.
    Cheers
  13. Purité Audio
    There is a ‘limits’ button by the spanner top right,
    Keith
  14. Sam Smith
  15. Purité Audio
    Sam press the EQ button on the header and these panes will open,
    press
    calculate target level from response
    then from ‘Filter Tasks, hit ‘match response to target’
    There is a little how to in the trade section I just posted yesterday that might help.
    Keith
    gustav_errata likes this.
  16. Sam Smith
    Did I don't wrong I'm assuming :)
  17. Purité Audio
    No not al all, but we need to bring the measurement down to the black line in your photos, ideally what we are looking for is a flat response which is slightly down tilted more bass and slightly less treble.
    Keith
  18. Sam Smith
    Ok does thats a bonus it matter that I clicked theb 1/6 smoothing button?
  19. Purité Audio
    Also treble really rolls off quickly in both channels did you place the microphone at ear/tweeter height?
    Keith
  20. Sam Smith
    Yes, from the listening position
