albireo
A longtime Nikon user, I have been contemplating the purchase of a small mirrorless setup for a while. the Fuji X-system of course attracted my attention - it seems like a good compromise of features, weight, lens range and sensor characteristics. So I borrowed a colleague's XE-2 and took a few quick sample snaps to see how the output compares to the Nikon's.
I was quite surprised to see, at 100% magnification, on a good number of my test pictures, a curious pattern. It looks like a soft smearing of detail in busy parts of the photo. In my mind it looks similar to one of those Adobe Photoshop creative filters that appear to blur fine detail for creative effect.
Has anyone noticed the same on their Fuji XE/XT photos?
A few details. I only tested in camera jpegs - no raw. The camera is running a 4.01 firmware, which I'm told is the latest and greatest, and brings its performance and features on par with the X-T10. The lens was a 27mm f/2.8. Disappointed by the first batch of photos, I trawled through the menus and, thinking it was some kind of oversharpening issue, I changed the NR to -2. There seems to be no way of deactivating the Noise Reduction altogether on this particular model. The issue persists, albeit in diminished form, at this low NR level. The following is a resized/cropped test sample with NR set to -2
[/IMG]
and the following is a 100% crop from the original out of camera jpg, showing the curious pattern (please click the yellow bar to resize) I was referring to. Note in particular the dry grass in the middle and the bench on the right:
[/IMG]
Is this normal/acceptable behaviour for this sensor?
