sticking power switch nap250
Discussion in 'audio' started by snaphappybob, Jul 16, 2020.
  1. snaphappybob
    snaphappybob pfm Member
    Went to turn on my amp this morning and the switch isn't working.
    It's been sticky for a while, not popping out when pressed but now it's not turning on.
    I have it open and it appears to all connect and work but still sticks.
    Any clues on how to sort this out?
    Cheers
    in advance
    Rob
  2. Nero
    Nero Wiped Clean
    The power supply for the switch needs recapping
  3. hp1
    hp1 pfm Member
    Is it CB or olive?
  4. snaphappybob
    Olive.
    I have now managed to free it up but it wont switch on.
    Swapped mains fuse and tried switching the iec fuse with the one in my hicap.
    Still won't power up and neither will the hicap. HELP
  5. snaphappybob
    I can only imagine that the fuse ratings are different and that trying the fuse from the hicap, the 250 has blown that one too.
    Answers on a postcard?
  6. snaphappybob
    Is this something that is easy to do for an idiot like me?
  7. Nero
    Nero Wiped Clean
    I'm ashamed to say I was being ironic. My sense of humour is failing me today.
    As you were
    booja30 likes this.
  8. hp1
    hp1 pfm Member
    If the 250 is a later one it needs a 5 amp anti surge fuse for 230v use, should be marked t5 ,t for time delay. it should give the rating on the rear panel.
  9. snaphappybob
    Yeah, it says T5A. I've ordered some fuses from Cymbiosis so fingers crossed that's the issue.
  10. hp1
    hp1 pfm Member
    should be a spare in the fuse holder pully out bit.
  11. snaphappybob
    It's working now, there was no spare and like a complete nob i put the fuse back in the spare slot.
  12. hp1
    hp1 pfm Member
    We have all been there. The switch button can foul on the rim of the shroud causing it to stick in. unplug the amp from the mains and switch the 250 on and off about 50 times see what that does.
  13. Mr Pig
    Mr Pig ^'- -'^
    The NAP250 has a power switch??
