Hi guys, I recently bought a Yamaha Pro P2350 PA to have a play about with two different pairs of speakers but mainly to try to hear a pair of Elac BS 312 as I don't think I'm getting the best out of them with my 'normal' amp which is a Yamaha R-N803d receiver.
I set up the Yam PA amp with my streamer/Dac set up which is a 1 TB HDD>RPi3>Topping D10s>RCA inputs via VLR adaptors and used the volume control on my laptop/phone via the Volumio webpage and set the attenuators to around 25 with the volume control in Volumio at 100 the speakers sound fine, not much different from my receiver to be honest but I'm wondering if I can use my R-N803D into the Yamaha PA amp and control the volume with that or is that a waste of time?
There are no pre-outs on the 803D but there are two line-outs however I suspect they're only for the specific line outs @ 2 & 3, according to the manual line 3 is for a CD recorder etc and presumably so too is line 2 (tape deck or similar) so I'm thinking that I can't use those line outs to hear all the of the inputs on the amp via the PA amp?
There's a sub woofer out though I suspect I can't use that either?
I have my TT connected to the Line 1 as it has it's own phono preamp but there's also a MM phono stage which I'm not using and I have my Panasonic Freeview recorder hooked up to coax 1 for sound from the TV.
The Dac is just a USB dac with RCAs out to the N-803's CD inputs which I've been hooking up straight to the PA inputs then switching everything back to listen to DAB+ or FM radio or the TV.
I wouldn't mind keeping the Yamaha PA if I could use the N-803 inputs/volume control or just sell the two amps and buy something more suitable, I did consider buying a Blusound Node 2i to use with the Yam Pa amp but I'm not sure if that's just a sideways step as the N-803 is very convenient but I'm sure that the Elacs need a better amp than the 803-D.
BTW, the attenuators on the Yam PA are 00 to 0 so should I set them to 0 and set the Volumio volume to 100 then reduce that or do it the other way about?
Thanks for reading.
Tony
Thanks for reading.
Tony
