Stereo audio RCA switch box recommendations
Discussion in 'audio' started by ToTo Man, Oct 17, 2020.
  1. ToTo Man
    ToTo Man the band not the dog
    I need a switch box that will let me switch between two (minimum) or three (preferable) analogue inputs.
    Most of the units I see on eBay are bargain basement prices, - that's not to say they're not transparent but you do have to wonder when they're selling many of these for a tenner!
    Also most of the switchers I've seen are AV/Audio switchers and include composite video in/outs which I do not require.
    I need a box that either has a rocker switch or push buttons as I can't twiddle a knob. ;)
    I checked on the Kramer site to see if they had an RCA version of the VS-4X I bought but they don't seem to, all I can find is this one which I'm not sure if suitable given it also has video in/out.
    Other options include:
    www.ebay.co.uk/itm/Audio-Switcher-Dual-Channel-Fentronix-Gold-RCA-Phono-Connectors-2-1-1-2-Black/184420291303?hash=item2af04e52e7:g:cL4AAOSwzp1d-MOp
    www.ebay.co.uk/itm/Audio-Switcher-RCA-Phono-Gold-ASPHO1METPRO-Switch-2-Stereo-Device-Black/184486843025?hash=item2af445d291:g:Z3gAAOSwhNVc1KfL
    www.ebay.co.uk/itm/Audio-switcher-Stereo-ASPHO1MET-RCA-Phono-2-Channel-Plain-robust-Diecast/184486842643?hash=item2af445d113:g:H9UAAOSwT6pVp2wc
    www.ebay.co.uk/itm/3-Port-Stereo-Switch-CD-AUX-RCA-Input-Audio-Change-Sound-Music-Selector-Switcher/351457314573?epid=1304306252&hash=item51d47d070d:g:dpEAAOSwUPZbPIpo
    www.ebay.co.uk/itm/6-Way-Audio-Input-Selector-Switch-Box-Stereo-RCA-Phono-Switcher-Home-Install/154073853078?hash=item23df846c96:g:Q3MAAOSwqqNfd42a
    www.ebay.co.uk/itm/4-Port-AV-Audio-Video-RCA-4-Input-1-Output-Switcher-Switch-Selector-Splitter-Box/184413810984?hash=item2aefeb7128:g:LJUAAOSwG-dfQQ9A
    www.ebay.co.uk/itm/Audio-Signal-Splitter-4CH-Lossless-Stereo-Signal-Selector-Switch-RCA-4in-1out/273788172604?hash=item3fbf0bf93c:g:xT8AAOSwHGFcoiST
    www.ebay.co.uk/itm/6-Way-Audio-Switch-Splitter-Mixer-W-4-RCA-L-R-inputs-2-Of-3-5mm-Inputs/352338901084?hash=item520908f85c:g:wEcAAOSwp~VcZJpD
    www.ebay.co.uk/itm/Switch-Selector-Audio-Video-4-Ports-Rca-Svhs/362643869630?epid=1604779128&hash=item546f424fbe:g:sY0AAOSwyDFbK6Ji
    www.ebay.co.uk/itm/Input-control-Feed-RCA-Phono-Audio-Switch-3x-2x-RCA-Female-to-2x-RCA-Female/372935323479?hash=item56d4ad6f57:g:SXAAAOSwRKRfc2dj
    www.ebay.co.uk/itm/Audio-Hi-Fi-RCA-CD-Tuner-Combination-Switch-Controller-TC-7/233724487448?hash=item366b10a718:g:E6MAAOSwMqtfbQN~
    Some advice would be much appreciated. :)
  2. Amber Audio
    Amber Audio This is the Day
  3. demotivated
    demotivated pfm Member
    ToTo Man likes this.
  4. jimpey
    jimpey pfm Member
    Search QED SDR Richard.
    There aren't may on ebay at the moment but I have one languishing in a cupboard like the canadian listed one. Just run the pot wide open.
    If it will do what you need (even if only until you find the ideal item) let me know.
    Jim
  5. Brucedgoose
    Brucedgoose Well-Known Member
    I’ve tried the ones by Niles, and they’re poorly made. The Radio Shack units are all over Ebay, but they look even worse than the Niles. Much better are the Sony’s, either the SB-300, which uses push buttons and works well (I own 2) or the SB-500, which are really nice, with very good switches and labeling (2 more!). Note that the Sony’s are, strictly speaking, for tape decks and they have tape outputs as well as line inputs. You can just ignore the tape outs if you don’t need them.
  6. brab
    brab pfm Member
    If you're happy with your Kramer, you can use it with RCA to XLR cables. I use Monoprice with my XLR switchbox from Mapletree Audio and find no signal degradation.
  7. delange
    delange pfm Member
    You might want to look at a passive preamplifier. Just turn the volume knob al the way up if you don't need the volume control.
    Here's one example: https://www.tisburyaudio.co.uk/mini-passive-preamplifier
  8. ToTo Man
    Nice!
    Yes, most of them are pretty lightweight. I can manage operating the Kramer unit ok by placing the fingers of my right hand on top of the unit to hold it down and then using my thumb to push the buttons in. This wasn't as easy with the previous Nobsound switch I had. I could probably manage an upward-facing rotary switch mounted in a heavy casing but buttons or toggle levers would be preferable.
    I appreciate the offer, Jim, but I'd prefer to keep the signal path as simple/pure as possible so not sure I'd want to introduce a pot into the circuit.
    This isn't a bad idea actually, thanks.
    I hadn't thought of this, thanks.
    I'd rather avoid a unit with a volume control, plus the Tisbury has forward-pointing rotary switches which I find too difficult to operate, - I'd need one with push buttons or toggles.
  9. gints
    gints pfm Member
    Tisbury has second exit, passthrough
  10. mr sneff
    mr sneff pfm Member
  11. Jim Audiomisc
    Jim Audiomisc pfm Member
    TBH I'm quite happy with ones I buy from CPC/Farnell. I've tended to prefer the rotary switches, but I think they also sell interlinked button ones.
    The rotary switches do tend to wear out eventually. But the switchboxes are so cheap I either buy another one or replace the switch. They lack 'street cred' of course, but I use them with my old Armstrong 626 to feed in external sources like a DAC, CD player, etc, and add an internal attenuator to suit the 626. Do much the same with other kit.
    You've set me wondering if anyone has even used the same approach as inside the 626. This uses switching diodes. An external box could do this using a battery and can 'cross fade' the inputs to avoid any clicks. :)
  12. James
    James Lord of the Erg\o/s
    What you want is the Pioneer U-24. You can switch between several power amps/loudspeakers, tape decks and sources at will. All push-buttons, passive switching and you won't need to hold onto it when pushing its buttons.
    booja30 and ToTo Man like this.
  13. audiopile
    audiopile pfm Member
    Using a Emotiva Stealth SP-1 - four inputs switched via button or remote control -relay switched -but except for the fourth input which is a MM/MC phono stage -entirely passive. I like this well enough that I'd buy another one if I ever come across it ( Discontinued product).
