nickcase
Enlightened Member
Hi All,
With the recent release of the raspberry pi model A+, I've been able to realise a long standing plan for my Tivoli Audio DAB radio.
The idea is to add squeezebox functionality to this funky little DAB/FM radio
This was achieved using the following:
1x Raspberry Pi Model A+
1x Edimax 7811UN wi-fi USB module
1x 1GB micro-sd card
1x 7805 TO220 5V regulator
piCorePlayer
Some wire, solder, hot glue and a bit of hacking!
Total Cost £25
Method:
1. Build the Raspberry PI model A+ with piCorePlayer.
piCorePlayer is available here
Install and configure it for your wireless LAN and test it all works before moving on.
2. Open the Tivoli radio and:
a. Hack the power board and fit a 5V regulator to power the pi.
Here you can see the board with a single pilot hole for regulator towards the bottom of the pcb.
here it is with the regulator in place. I decided to mount it the other way around in the end to reduce wire lengths.
and here is the reverse of the board when its all wired up and glued in place.
b. Next step, hack the input board and create a feed for the AUX input from the pi.
Here is the reverse of the board
and here it is with the leads attached to the appropriate points.
2. Next, hook up the RaspPi to the new 5V power feed and the audio output to the new feed into the Tivoli input board.
There are some nice shiny test pads on the Raspberry Pi which are ideal for this.
Here is a rear view:
The pads to use are:
PP1: 5V power feed from microUSB (prior to fuse)
PP3: Ground
PP6: Ground
PP26: Audio - R
PP25: Audio - L
Solder the connections to the Pi.
3. Lastly, find a spot to cram the RaspPi board in.
The model A+ and wi-fi dongle just fit in to the right hand side of the bass port.
Route the cables so they do not interfere; like so:
4. Lastly power up and watch for smoke!
All looks good!
The result is that the radio works exactly as before but the AUX input now functions as a fully functional squeezebox.
Here she is:
Control is via the SqueezeCentre web panel or your mobile phone.
Works a treat!
Cheers
Nick
piCorePlayer
Total Cost £25
Method:
PP3: Ground
PP6: Ground
PP26: Audio - R
PP25: Audio - L
All looks good!
Here she is:
Works a treat!
Cheers
Nick
