Speakers that work well with Farlowe era amps?
Discussion in 'audio' started by madscientist, Jun 20, 2014.
  1. luuguxd
    luuguxd pfm Member
    Can i combine royd rr3 with exposure vii, viii power?
  2. PerF
    PerF Scandinavian Member
    Should be no problem, those amps are very old, probably 30+ years, I'd have them fresh serviced if possible (if not already done).
  3. luuguxd
    luuguxd pfm Member
    compared royd rr3 with epos 11, which speaker sound better?
  4. PerF
    Do you like apples or oranges better ?
    Both speakers are excellent, whichever you like better - nobody but yourself can answer that..
    Wilson and deltaunit like this.
  5. luuguxd
    luuguxd pfm Member
    I using epos 11, i want upgrade royd rr3
  6. puddlesplasher
    puddlesplasher pfm Member
    I’ve had good results with Naim SBL’s passive and active, Kef, Royd, Ruark and Neat. Going to try a pair of Heed Enigma 5’s soon and would like to give Shahinians a go some time.
  7. RustyB
    RustyB Registered Ginga
    Totems are another option. Tabu's on the end of VII/VIII are superb, though size of room is limiting, as the Totems are low 80's in sensitivity.
