Over the last 12 months I built an Audio Note based system. My amp is a 5 year old OTO line SE Signature. I changed the stock valves to Telefunken ECC83 and the biggest joy and surprise the EL84 HARMA CRYO BURST from Watford Valves. They took some time to arrive (thanks again Brexit...), but unbelievable value.
My speakers are a 20 year old AN E L. One of the drivers was replaced, but I am starting to feel they need a serious refesh (or replacement). The second issue I have with them is that my current audio room is small and the speakers are probably oversized. I also do not have a perfect corner on the left side as the room is under our roof. We're building an extension to the house which hopefully will be there late next year and will also have a bigger audio room.
While I do that, I would like to get a pair of speakers that will fit better my current space, but do not want to change my amp. This mean I need more compact speakers that can give the Audio Note a run for the money on an Audio Note amp. I already thought the Js but wanted to hear if anyone is using none Audio Note speakers as well
