Speaker recommendations for a 300B SET amplifier - small room
Discussion in 'audio' started by Yivez, Jan 18, 2022.
  1. Yivez
    Yivez Active Member
    I am looking for recommendations for a speaker suitable for a 300B SET amplifier (9W) that can work 6ft(1.8m) from my listening position and can't be more than 50cm from the front wall. The speakers are positioned just over 2m apart, and there is over a meter distance from sidewalls.
    I tend to like bookshelf speakers or speakers with a small footprint. However, they need circa 90dB or more to get the best from the system in terms of sensitivity. There doesn't seem to be a lot of choices. Am I chasing rainbows?
    Happy to buy second-hand or new and budget is up to £4k.
    Your help is much appreciated.
  2. oldius
    oldius Can pleasure be measured?
    300B amps work best with efficient speakers. Unfortunately, that is hard to properly achieve with small boxes and I, personally, would rethink your amplifier choices given your room.
  3. mr sneff
    mr sneff pfm Member
    These work well close to the wall in small rooms and with small tube amps
  4. mr sneff
    mr sneff pfm Member
    You'd need to make a quick decision though, 2 or 3 people are suddenly interested.......
  5. PerF
    PerF Scandinavian Member
    Snell/Audio Note K will fit purpose
    Wilson, sjs, Si74 and 2 others like this.
  6. Yivez
    Yivez Active Member
    Thanks this is one speaker I had considered and ideally try in the room
  7. chris@panteg
    chris@panteg pfm Member
    Definitely Snell or AN K. Get the right stands too.
    Miss Ariel likes this.
  8. Bairnstorm
    Bairnstorm pfm Member
    Tannoy used to do a little speaker. Can't remember what is was called.
  9. TCar
    TCar pfm Member
    Autograph Mini but it's not 90db. I used them with a 12 watt Leben cs300 but dont know if they would work with this amp. Very fine little speaker it is though
  10. RoA
    RoA pfm Member
  11. anubisgrau
    anubisgrau pfm Member
    autograph mini, strangely it is not for a low powered amps
  12. RichardAusten
    RichardAusten pfm Member
    You might also consider the AN J - It has significantly deeper bass and more dynamic ease. Can be placed right up against the wall as well and about 3dB more sensitive.
    They really aren't that much bigger - it will depend on the room interaction. (K,J, E)
    I love the K - Owned a set in 2003 and own a pair again today along with the E and AX Two.
    I also had the J/SPe for 13 years.
    Shove em into corners if you have them available
    (Gearbox Records)
    PhilofCas, Vincent52 and chris@panteg like this.
  13. Yivez
    Yivez Active Member
    Thanks for sharing. I hadn't considered the AN-J's (size) but looking at the image they are not much bigger but with greater sensitivity and frequency response.
  14. hifinutt
    hifinutt hifinutt
  15. Linus
    Linus pfm Member
  16. Darren L
    Darren L pfm Member
    Klipsch Heresy? Tannoy Eaton? Living Voice? It's not exactly easy to find small speakers that are very sensitive but perhaps some larger sensitive speakers will work in a smaller room?
  17. Euan
    Euan pfm Member
    In my experience LV won't work with flea powered amps. I had a 16w 845 and the OBX R2s were a poor match.
  18. cupples
    cupples pfm Member
    Triangles tend to have higher sensitivity and in my experience work well with valves, but I've only used smaller bookshelves such as Cometes, although the Titus is often recommended.
  19. daytona600
    daytona600 Registered User
    Used opera Callas with 9wpc 300b in near field.in a small room Sound like a LS3/5a with better bass & dynamics
    Italian so Also look fantastic
    Callas - OperaLoudspeakers EN
    Salamander, Linus and hifinutt like this.
  20. Yivez
    Yivez Active Member
    They certainly look the business!
