Speaker Cable
Discussion in 'audio' started by Rushboy, Oct 6, 2019.
  1. Rushboy
    Rushboy pfm Member
    Do you have a recommendation for a speaker cable that is not so expensive?
    it should play very clearly, the basses do not inflate.
  2. Jamie
    Jamie pfm Member
  3. whatsnext
    whatsnext Naimless
    It may help if you say what your speakers and amplifier(s) are. Generalisations otherwise
  4. Rushboy
    Rushboy pfm Member
    Exposure 3010 S2D and Shahinian Arc.
  5. Martyn Miles
    Martyn Miles pfm Member
    QED 79 strand.
    Shadders and Musicraft like this.
  6. Cereal Killer
    Cereal Killer fourhundredandthirtytwo
  7. davidsrsb
    davidsrsb pfm Member
    And how long the cables need to be
  8. Rushboy
    Rushboy pfm Member
    5 meters per channel
  9. Rushboy
    Rushboy pfm Member
  10. davidsrsb
    4mm2 conductor is fine at 5m
  11. AKG
    AKG pfm Member
    Rushboy likes this.
  12. hifinutt
    hifinutt hifinutt
    Rushboy likes this.
  13. Julf
    Julf Facts are our friends
    You mean "NAIM or not NAIM"? :)
  14. Rushboy
    Rushboy pfm Member
    No Naim
    Julf likes this.
  15. Yomanze
    Yomanze pfm Member
    Rushboy likes this.
  16. notevenclose
    notevenclose pfm Member
    You're Clint Eastwood?
  17. Rushboy
    Rushboy pfm Member
    No James Bond
  18. philiphifi
    philiphifi pfm Member
    I tried some silver (homemade) cables. They are very very good. Transparent and detailed. I think if the length is not too long then think cables are fine so you won't have to spend alot of money
  19. Vinny
    Vinny pfm Member
  20. Musicraft
    Musicraft Trade: Musicraft
    +1. We only use basic 79 strand or basic 500 strand speaker cables.
