Elephantears
Trunkated Aesthete
If you've never fitted a cartridge before, and what you want is to fit and forget for a long time, then now is not the time to learn. You want it perfect, and you aren't likely to get that first time, at least without a good alignment tool.
I suggest that you either get a dealer to fit it, or see if any other forum members in the area are willing to help. Probably the ideal arrangement is to stick with a dealer, because if anything goes wrong with someone else trying to help it is then an awkward situation. If you bought something else from a dealer as well as the cart, such as a phono stage, then I'd expect them to set it up for you for free. I think a good relationship with a dealer would be the best thing to aim for here. If they are generous they might set it up for you anyway.
