Ciunas Audio
Trade: Ciunas Audio
So here's some evidence I posted of a blind listening test but it was buried in another thread.
It might be useful to examine it & determine some issues related to blind testing & evidence?
But first an explanation - the test uses Foobar & its add-on ABX. Anybody who has used Foobar ABX will know what the figures mean but it's worth explaining a bit about ABX & what the results mean.
Essentially, ABX is a utility add on to Foobar that can allow you blind test whether you can hear the difference between two selected audio samples/files & identify them correctly & give you the statistical importance of your test trials i.e how close to guessing you are. It's a blind test - you don't know which file is which - they are randomly named X & Y for each trial & you have to say which original file X is? Is it the original file A or B
The numbers show each guess/trial & whether correct or not & the third number is the cumulative probability that you are guessing - a figure below 0.1% is very significant & means that it's almost certain (statistically significant) that you are not guessing in the test.
So for a 95% confidence level
Number of trials operated 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
Minimum number correctly 9 9 10 10 11 12 12 13 13 14 15 15 16 16 17 18
