Solid state with output traffo?
Discussion in 'd.i.y.' started by bugbear, Feb 28, 2023.
  1. bugbear
    bugbear pfm Member
    I've been sniffing around eBay for a while, hoping to buy big ol' broken power amp to repurpose its case.
    Recently I saw a commercial (PA, or similar) Phillips. Not too many details, so I GIS'd the model name.
    One of the things I found was a slightly different model, with TWO big toroidals, mounted in a very assymmetrical fashion, which struck me as odd for a stereo amp. Looking at the back panel, with output sockets stated for various voltages, I looked again the right hand (as seen from the front) traffo.
    As far as I can reckon, it's an impedance matching output transformer, albeit that the output is specified in volts, not ohms.
    (It also has a 135-alike-fan-assisted-heatsink-tunnel)
    [​IMG]phillips_top by plybench, on Flickr
    [​IMG]phillips_output by plybench, on Flickr
    Thought it was interesting.
  2. wd40addict
    wd40addict pfm Member
    It's a 100V line jobbie for PA use.
    martin clark likes this.
  3. bugbear
    bugbear pfm Member
    Or 70V or 50V!
    (and thank you)
