A lot of Naim kit has the necessary connections to take a DC feed so not out of the question...Great question OP and one which i have been thinking about for a while. Unfortunately i am in a small flat so the chance to play with a Solar set up has not happened yet.
Although the general consensus on whether the sound quality is impacted seems to be no, i was wondering if you were in an 'offgrid' set up then would the quality of inverter -for example - effect the sound ?
I also wonder what would happen if you could design an amp to run straight off 24V DC, bypassing an AC/DC conversion, if that would improve the sound ? But i guess thats going off on a tangent now !
Its an interesting area in any case.
I guess thats their fundamental business model. using external power supplies !A lot of Naim kit has the necessary connections to take a DC feed so not out of the question...
Lithium batteries will not be disposed of any more than existing LA batteries in the waste vehicle stream. There is too much residual value. Ask any plumber how much copper piping he throws in a skip. None, if he can avoid it. He keeps it in a corner and weighs it in.
The energy cost in making a car is about the same as 50,000-100,000 miles of normal use.The general view is that half of the energy a car uses in its life is in making it. I don't think that EVs cost much more in energy to build, batteries aside. Indeed, they don't have engines, gearboxes, fuel pumps, coolant systems and the rest. But as you say this is not about green issues. It's about keeping the car industry rolling by killing old cars, because an old car costs very little other than fuel to run. Once a year a service, MoT and replace a few worn out parts? Big deal. Nobody is making a fortune on that compared to selling you a new £30k machine, then the same again in 5 years.
The solar panels won't, they can't. They generate DC. Any interference will come from the inverters that convert this to AC, with varying degrees of accuracy and precision. If the installation can feed back to the grid there are stringent rules on the quality of what can go back, mostly relating to frequency.When we installed solar panels at our work interference bands appeared on the tv screens in the reception. At the time I was advised that solar units put some interference back down the mains. Can't be sure they were linked. The tv's were replaced with better ones a couple of years later.
I agree it's the inverters, I was being a bit economical with my words. Two of the four inverters have failed after 8 years.The solar panels won't, they can't. They generate DC. Any interference will come from the inverters that convert this to AC, with varying degrees of accuracy and precision. If the installation can feed back to the grid there are stringent rules on the quality of what can go back, mostly relating to frequency.
What energy mix were they using for the calculation (g/kWh)?I've seen two sets of data both reaching the same conclusion, one a fully fleshed out study. In the study, comparing total CO2 (including that from manufacture) over the first 8 years of usage in Germany a diesel E Class Merc produced 40% less CO2 than a similar sized Tesla. Once the Tesla is onto its second battery the CO2 gap open much wider, batteries according to Polestar increase CO2 for production of a new car by 50% compared to its internal combustion equivalent.
Guys,
Thank you for the experiences much appreciated. I'm in a conservation area, but solar shouldn't be an issue other houses have it as such I think that will be fine. The battery point is very valid. One of my big gripes with electric cars is the Co2 in production and safe disposal of lithium batteries vs petrol cars pollution . I suspect that on a total vehicle lifecycle running my 18 year old Mercedes will still be greener than buying an electric car, sadly the government doesn't see car tax that way!
I will be installing just over 6KW of panels as such the commercial case for battery is pretty good. Solar overall isn't as exciting as it used to be and if I wasn't looking at an ASHP I probably wouldn't bother.
Jenny
