Jennifer F
Hi,
I'm interested to hear if anyone here has had solar panels installed on their house and a battery / inverter system fitted. Specifically whether this has had a positive or negative impact on the hifi.
I'm currently investigating putting quite a large solar array on my property to offset running an Air Source Heat Pump, but I'm keen to understand whether this will have a positive / negative or zero impact on the hifi and whether I may need to try and feed the hifi without the battery system in the loop.
Many thanks
Jenny
Many thanks
Jenny
