beammeup
... so does it? Information from Auralic's website:
https://support.auralic.com/hc/en-us/articles/235639187-Firmware-Version-4-1-0-Build-20161128
Introducing advanced Software Volume Control function. The newly designed software volume control use 64bit fixed-point calculation precision with proper dither algorithm to optimize the sound quality. You should expect great sound quality improvement while using software volume control to play 16bit and 24bit music files
If I play nothing higher than 16 bit digital (CD quality) - will the 64 bit software volume control give enough headroom so that there is nothing deleterious to the bits when using software attenuation?
