[WTD] Small amount of EP90 GL4 Oil needed for turntable bearing
Discussion in 'd.i.y. classifieds' started by Chaggy78, May 20, 2019.
  1. Chaggy78
    Chaggy78 pfm Member
    Hi
    Does anyone have a small amount of EP90 GL4 (gearbox oil) oil that I could have for my Systemdek iii turntable bearing?
    This is the oil it says to use in the manual and I only need 0.8ml but could do with a little bit extra.
    Thanks kindly!
  2. JimmyB
    JimmyB pfm Member
    So lots of oils will do the job fine, the GL4 is for yellow metals but Audio Origami have a small bottle of Linn oil for about £6. Way more expensive that a litre of EP90 but if you only need a tiny little bit.....
  3. Chaggy78
    Chaggy78 pfm Member
    Thanks for your reply much appreciated. The manual suggests that it has to be a high pressure oil, if the Linn oil is that I may buy a bottle.
  4. Martian Sunrise
    Martian Sunrise pfm Member
    I’ve got a gallon of it. I’ll need to check that it is gp-4 when I am home.
    Where are you?
  5. Chaggy78
    Chaggy78 pfm Member
    Hi Martian thanks for your reply I am in Penzance in Cornwall. Thanks!
  6. Martian Sunrise
    Oh mate! I am in Cornwall on holiday. I’ll be in Penzance tomorrow!
    The oil is in London.
  7. Chaggy78
    Chaggy78 pfm Member
    Hi mate ahh no way!! not to worry I think I'll just end up buying a litre of it from ebay it's not too expensive but thanks anyway.
  8. Martian Sunrise
    I’m happy to post you a little bottle if you want
  9. JimmyB
    JimmyB pfm Member
    Your local garage will have some handy, probably just need to take a 5ml syringe and ask!
