Dan, i've done some experimenting with DC motors etc on an LP12. I originally used the diy motor controller which I got from someone here and used it with several different pulley arrangements and speeds.
Essentially the controller could not compensate for stylus drag and so ultimately was no use. Also subjectively it was dramatically inferior to the Linn Radikal. I also learned that they inject ridiculous amounts of mechanical noise in to the top plate. However I recently installed a new DC set up which works on a similar (ish) principle to the Radikal from Edmond (of Hercules fame) - this was an early prototype unit and uses 4 markers per revolution to track speed as opposed to Linn's single one.
Again the mounting system for the motor was a weak area being directly connected. I changed the motor and also mounted it in a foam pot to reduce resonance. It is not as sophisticated as the Radikal in terms of getting up to speed and stabilising, however once there it now measures very similarly to the Radikal and subjectively sounds very similar. At 45rpm it is almost identical and hard to tell apart.
I have limited electronic expertise (non existent) so my work has mainly been focused on how the motor is mounted physically and this has had considerable influence on the outcomes. I have not gone back to re try the diy dc controller with this new mounting system so must get round to trying it. I'm not familiar with how the PT Too arrangement works but would certainly suggest investigating ways to isolate the motor.
The voltage across both the resistor and the transistor wanders around between 8.1 and 8.15 volts, measured over 20 minutes this morning
Across the transistor it's a stable 2.49V
Hi TPA, is there any chance that you could PM me contact info for Edmund? I'm not on Vinyl engine
thanks
Dan
