I think this should go to a new thread?
Dan, what actually is the symptom?
I think the voltage regulator for a dc turntable motor is almost irrelevant, anything will do the job as long as it can supply the current. The physics are that a dc motor must slow under load. The speed of the motor is a consequence of its windings, magnets, geometry and the applied voltage. The motor spins at a rate that generates a voltage that balances the supply. With a perfect motor, as you apply load the current rises and any regulator will continue to supply the same voltage balanced against the voltage generated by the spinning. But because real motors have resistance as the current rises this generates a voltage, which must be added to that generated by the spin, to match the supply. So the motor slows. It doesn't matter how excellent the supply is, this must happen.
There are two ways around this.
1. Use a big motor turning slowly, it has a low internal impedance and the slowing under load drops to insignificant at the loads seen in a turntable. I think this is the Radikal approach. The speed measurement on the Radikal is so that the user doesn't have to adjust the speed for temperature, pressure, weight of record, whatever. It's not about moment to moment compensation.
2. Use a PSU with a negative output impedance, as discussed in this thread. The effect of this is that as the current rises under load the voltage delivered also rises, hence constant speed by magic.
'2' is difficult, especially to make general. Probably best with a small motor turning quite fast. You actually want a high internal impedance to make the compensation more sensitive.
No idea what the OL supply does, I suspect from other posts in this thread that it is a simple regulator. And hence rather pointless if expensive.
Paul
