Can't you just remove the spikes and use stick-on rubber feet?Hello All
I am wondering if anyone knows of a screw in rubber foot for the Kan ii stands. I have wood floors that I don't want to mark up.
If going with stick-on rubber feet it has to be 3M Bumpon™. Suggest SJ-5514 (BLACK). These are of polyurethane substrate and have a Shore hardness rating of 72 (ASTM-D2240, a hard hat is 80 on the same scale) combined with a tensile strength rating of 600lbs/sq in(!), IOW Über-Bumpons™ . I've used these as replacements under some pretty heavy amplifiers.Can't you just remove the spikes and use stick-on rubber feet?
