I recently spotted the great job in the reference area describing DIY SBL gaskets https://pinkfishmedia.net/forum/threads/diy-sbl-gaskets.200610/
I thought I knew what I was doing with SBL set up, I diligently use washing up liquid on the gasket and bottom of the cabinet, and thought I did a good job with the sealant, but I now realise my SBLs have no aluminium pads on the cabinets ... oh. I think it is time I take my SBLs apart and put the pads in!
I can see a link in the reference area to 0.3mm aluminium foil rolls on ebay http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=272029424701, and it mentions the original were "0.28mm aluminium sheet" but how big are these pads? Can anybody tell me the width and length? The DIY guide also mentions that they are double sided taped on to the cabinet then stapled or as they did it nailed? I assume that is very thin double sided tape ... any further advice would be appreciated! Thanks
