stephen_cowslip
Hi all,
Hope you're well.
I'm a little confused as to what settings I should use on my Saunsui AU 11000 A with regards to Phono.
I have a Linn LP 12 with Ortofon 2M Red, plugging straight into the phono stage on my Sansui:
Sounds OK but are these the settings I should be using? (30k / 2mv)
Thanks in advance, as usual.
Stephen.
Hope you're well.
Stephen.
