RyanSoundLab
Trade: Ryan Sound Lab
Roger,
Thanks a lot for the XLR info. I couldn't find any general info on it but this wiring makes a lot of sense so I will follow it. I was asking because one of my customers has them on his turntable. Regarding whether it is superior to RCA or BNC, I can't say because my turntable outputs are BNC and I have no access to one with XLR. As you know, balanced XLR's are used a lot on stage where long cable runs can pick up noise. My turntable doesn't have that problem so I'm not sure it would be a benefit to me. I can't really tell the difference between straight BNC and BNC with RCA adapters.
Regarding "balanced" input - I also wanted a completely "balanced" input stage but could not figure out how to design a reasonable one for a current-mode circuit (e.g. didn't use a transformer). Maybe those Aquavox guys are a lot smarter than I am? It would be interesting to compare the two for sound but I suspect they would sound different no matter what.
What got me started on the current-mode input approach was comparing a Drynavector P75 voltage and current ("phono enhancer") modes with everything else being the same. No contest to my ears - current mode had much more information and was so much clearer and dynamic. I was going to try to provide both options by using jumpers (as complicated as that makes it) but decided that no one would want to use voltage mode after they heard current mode so why bother.
