RyanSoundLab
Trade: Ryan Sound Lab
Now available after over two years in development, the RSL Phono-Stage brings you hi-end turntable sound quality at a down-to-earth price. By using plug-in boards, it can accommodate either a MM or MC cartridge and can be converted from one to the other at a future time if desired. The RSL Phono-Stage comes complete with a separate linear power supply and custom cable to connect them. Compact and attractive, this stand-alone system will fit into almost any hifi system configuration.
Loaner available! See below to get on the list. Also, a review thread has already been started on PFM here: https://pinkfishmedia.net/forum/threads/ryan-sound-lab-phono-preamp-review.228038/#post-3675209
The RSL Phono-Stage is big on features, sound quality and value that you have come to expect from Ryan Sound Lab, including:
- Guaranteed RIAA equalization to better than +/- 0.3db for the most accurate sound.
- Extremely low noise for both MC and MM versions.
- Exceptional tonality – a piano sounds like a piano! You will want to listen for hours at a time.
- Musicality and toe-tapping that you’ve come to expect from RSL.
- Wide sound stage that brings the music into your listening room.
- Able to drive loads as low as 1k ohm for system flexibility.
- All internal connections are gold-plated for trouble-free service.
- RCA or BNC turntable input connectors available – your choice at no extra cost.
- 115v and 230v versions available. Comes with the proper mains cable for either US or UK.
- Two year warranty on parts and labor. If it fails, RSL will fix it or replace it for free.
The MC version has these additional features:
+ Uses "current mode" input (sometimes called "DrT" or "phono enhancer") for incredibly realistic sound. Nothing is lost in "compensation" resistors.
+ User adjustable gain to cover the low-output moving coil cartridge internal impedance range of 3 to 40 ohms.
+ Gain range approximately 58db min to 69db max. (cartridge dependent)
+16 power supply regulators in a 3-tiered system for superb sound clarity.
The MM version has these additional features:
+ Industry standard 47k input resistance (other values available at no additional cost if desired).
+ User adjustable input capacitance 47pf to 367pf in small steps for optimizing cartridge peaking
+ User adjustable gain of 40db +/- 3db (other gain values available at no additional cost if desired).
+12 power supply regulators in a 3-tiered system for superb sound clarity.
Rear view of the RSL Phono-Stage with power supply.
An internal view showing the plug-in boards and part of extensive regulated linear power supply.
Please see the Ryan Sound Lab website for access to the Owner’s Manual and ordering info. Pricing is set extremely low: MM version $699, MC version $799 + shipping (free shipping in the US). http://www.ryansoundlab.com.
***Loaner versions are available in the US and UK/EU for an audition on your own system. To get on the list, please send your name, address, and phone number to: [email protected] or directly to me at [email protected] ***
