Mr Magoo
Hello. How are you?
We’re downsizing our home and as a consequence I will be using my system in a much smaller room. This isn’t an issue for my source, but it seems unnecessary to have a 120 watt Sony TA-F870ES amp. It also raises an element of doubt over my speakers, although I’ll need to see how they perform before considering a change. They’re PMC Twenty23 speakers and they are not ideally suited for use against a rear wall. We’ll see how that works out.
The room is 11’3” long and 8’6” wide. Solid walls all round and solid floor. It will be a dedicated music room with some vinyl storage. The WTA Versalex tt will be on a wall shelf.
I see this as an opportunity to try Class A amplification and/or valves.i use a Dynavector 17D3 MC cart. Looking for suggestions to draw up a shortlist. New or used. Budget up to £3k, Will need to include a phonostage somewhere within this budget. Listen mainly to rock/prog music.
Many thanks
Pete
Many thanks
Pete
