Midlandaudiox
Trade: Midland Audio X-Change
Resolution Audio is proud to introduce the latest addition to our Cantata series: the m100 mono amplifier. This amplifier features the same discrete, ultra-pure Class A/B circuit topology as our highly regarded C50 integrated amplifier. With an increased rating of 100 watts. Now a full Cantata system can be enjoyed even when using less efficient loudspeakers.
Alan Sircom review in Hifi plus http://www.hifiplus.com/articles/resolution-audio-cantata-music-centerm100pont-neuf-system/?page=3
Power Output
100 watts into 8 ohms <1%
Input Sensitivity
700mV for rated output
Gain
+31.5dB
Inputs
XLR or RCA (jumper must be installed in XLR input)
Speaker Outputs
2 pair, 4mm banana
Red positive (+)
Blue negative ()
Yellow ground (if available on loudspeaker)
Power Requirements
Pre-configured at factory for either 100-120VAC 60Hz or 200-240 VAC 50Hz
Power Consumption
160 Watts maximum active mode, < 1 Watt in standby mode
Dimensions
43 x 23 x 5 cm (17″ x 9″ x 2)
Weight
6 kg (13 lbs.)
In immaculate condition full warranty RRP £7200 selling at £4999
Power Output
Input Sensitivity
Gain
+31.5dB
Inputs
Speaker Outputs
2 pair, 4mm banana
Red positive (+)
Blue negative ()
Power Requirements
Power Consumption
Dimensions
Weight
6 kg (13 lbs.)
