DAVEDWACK
Hi Folks,
I need to replace my 1 metre length power cable which connects a Russ Andrews 6-way distribution box to the mains with a piece of 4 metre mains cable.
Russ Andrews will supply it but they want me to send their cable back to them in order for them to fit it, which I find a bit difficult to understand. I mean how difficult is it to stick a plug on 1 end and connect the block at the other end!
I will probably just go down to B & Q but I dare say some-one here could give me some advice as to where/how to buy a decent piece of Mains Cable.
Any advice much appreciated.
Cheers,
Dave
Cheers,
Dave
