Hi all,
Been looking around for a while but first post here - so hello.
I'm after a bit of advice so hoping I'm in the right bit of the forum.
I am currently using a set of Proac Studio 125s to great effect partnered with a Sugden A28 (couldn't afford an A21 and wanted to try Sugden and ended up sticking with it....).
Problem is I am likely moving to another house soon which has smaller rooms and giving the Proacs the space to breathe anywhere will likely be an unachievable task. I am therefore looking for alternatives.
Not really sure where to go with this - I would love a set of baby floorstanders as I much prefer them to stand mounts aesthetically (not really the be all and end all though...). Current thoughts are either to swap out the Proacs price for price with some Neat Motive 2s. Or go much lower on the price and switch for some Royd Minstrels as I will likely move again in a year or so and can then match the system to my new place where I should be much longer....
All other suggestions welcome though as I am really not sure what options are out there in this price range/style of speaker.
Only other I have really considered are Rega R3s; if any ever surface....
I can't really go beyond the price I can get for the Proacs as don't have the cash.
Might be easier if anyone just has some Neat Motives to swap : p.
Alternative amp is a Yaqin MC10l which is an EL34 based valve amplifier - I much prefer the Sugden though as I find valves too fussy (I can also get more money getting rid of the Yaqin....)
Source is mostly vinyl. RP3 into a Tisbury Domino (which is an ace phono btw....).
Thanks in advance - all your help is really appreciated.
