Repairing old Rega Apollo?
Discussion in 'audio' started by GF670, Mar 9, 2022.
  1. GF670
    GF670 pfm Member
    I have an old Rega Apollo CD player (the full width version), which I bought new around 10 to 12 years ago. I remember that it worked reasonably well when I first got it, but became increasingly unreliable over the following year or two and then stopped working altogether. I never got round to having it repaired, and it's been boxed up in the attic ever since.
    A few weeks ago I brought it down and powered it up. It goes on, which I guess is a positive sign, but only reads 'Rega Apollo' (or similar) on the screen. It won't play discs.
    Given that it's in good cosmetic condition, I'm wondering whether it's viable or even possible to have it repaired?
  2. cnocmoy10
    cnocmoy10 pfm Member
    Phil of Cheshire Audio seems to be a bit of an all things Rega guru. I think it would be worth a phone call to ask what ,if anything, he could help with. watch his Rega repair videos on You Tube....very informative.
    Hope this may help. Good Luck.
  3. eevo1969
    eevo1969 pfm Member
    Phone or email Rega.
  4. Geoffreybombom
    Geoffreybombom pfm Member
    Using a cotton bud impregnated with isopropyl alcohol very carefully clean the laser lens first before sending it off for repair.
  5. GF670
    GF670 pfm Member
    Thanks yes just looked at his YouTube video of replacing an Apollo transport!
  6. GF670
    GF670 pfm Member
    Thanks yes I suppose this would be a good starting point though I appreciate that it’s a very old player by now
  7. GF670
    GF670 pfm Member
    Thanks though I wonder whether it’s something else wrong with the player as it doesn’t try to read discs or say the door is open etc
  8. Geoffreybombom
    Do you hear any sound at all when you insert a cd?
  9. Dowser
    Lasers are still readily available for the Apollo :)
    GF670 likes this.
  10. GF670
    GF670 pfm Member
    No nothing
  11. Dowser
    I can't remember if the Rega's even announce that the lid is open - but without a disc inserted you should see the laser trying to do something when you close the lid. Best way to confirm tray switch is functional is to wind the laser head away from the spindle with the lid open, then close the lid. You should see laser head move back to spindle before it tries to read TOC. If it does, most likely laser (likely: not definitely - a worn laser should at least attempt reading TOC, not doing so could be a power rail gone or low). If laser head doesn't move, then either lid switch or a power rail.
    Note: the replacement lasers have a solder blob as ESD protection - do remember to remove it before fitting the laser :) Last faulty Apollo I bought had exactly this problem - owner replaced laser, it didn't work and he sold it cheaply in frustration. I removed the solder and sold it on for large profit :D
    Neil P likes this.
  12. GF670
    GF670 pfm Member
    Thanks I will retrieve it from the attic again and have another look!
  13. Del monaco
    Del monaco Del Monaco
    There were some issues with the early versions. Rega very kindly looked at two of these owned by relatives and got them up and running again. I’m sure they will listen to your issues and act on these. I think they have exemplary customer service. Give them a bell.
  14. PerF
    PerF Scandinavian Member
    I believe its a Rega dealer network you need, not Rega directly.
    I had my old Saturn supported last year, spares sourced and fitted by local distributor tech, no need to have the player send into Brexit.
    Neil P likes this.
  15. eevo1969
    eevo1969 pfm Member
    Oh, is the OP in EU?
    I wasn’t sure if Rega still supported them hence contact Rega comment. Are official dealers happy to handle Rega product not purchased from them?
  16. Dowser
    If OP is in or close to Switzerland I’m happy to fix it for you :)
  17. PerF
    I have no idea of location.
    I'd expect any authorised dealer to be equal helpfull no matter where item purchased.
  18. GF670
    GF670 pfm Member
    Thanks that’s very kind of you but I’m in Wales for the time being
  19. Neil P
    Neil P pfm Member
    Indeed: rega have neither email nor phone on their website!
    lordibiza likes this.
  20. Geoffreybombom
    As your in Wales, as am I I can strongly recommend Acton Audio in Wrexham. They are really helpful. You may find the problem is the lid sensor switch.
    GF670 likes this.
