Boris the madcap
Hello,
Anyone knows, if the last rega wall bracket, are compatible with a rega p25?
Than you very much
Than you very much
OK, thank you.Yes; the 3 studs of the 2016 'Turntable Wall Bracket', that replace the 3 cups of old, align within the 3 rubber feet of 'classic' Rega decks, preventing the deck from sliding off if knocked.
Hello again,Yes; the 3 studs of the 2016 'Turntable Wall Bracket', that replace the 3 cups of old, align within the 3 rubber feet of 'classic' Rega decks, preventing the deck from sliding off if knocked.
Nope, the feet have holes in the middle which will sit over the there pegs on the bracket.Hello again,
One question more.
And to put the table on the bracket is necessary to remove the rubber feet?
Thank you.
I’d just put it at a nice usable height.I have to put the wall bracket between the
Speakers, what is the best place
Near to the floor or over the speakers
Thank you
